Billet alternator pulley
Old 08-24-2016, 07:31 AM
mizzou580's Avatar
Need advice on installing new billet pulley on alternator without damage. The old pulley came off fine. Some say heat up the pulley, use a press, c clamp. Any thoughts?
Old 08-26-2016, 12:27 PM
Nadir Point's Avatar
Assuming there's a nut/washer holding it down, just tighten it up with threadlocker blue and should be good to go.
Old 08-26-2016, 03:27 PM
mizzou580's Avatar
It's press fit.
Old 08-28-2016, 09:14 AM
SPAMBURGER's Avatar
On mine the center of the pulley shaft was threaded. I ran a tap through it to clean up the threads and used a couple of different length bolts to pull the pulpy onto the shaft.
mizzou580 (08-28-2016)
Old 08-28-2016, 10:01 AM
Press it off and then press back on.. If you have trouble, Take it to your local rebuilder... Just my 2 cent...
Old 08-28-2016, 10:59 AM
mizzou580's Avatar
I got it on by heating it and a c clamp. Thanks
Old 08-28-2016, 11:35 AM
Cool...
Old 08-28-2016, 01:06 PM
There ya go!
98 SNAKE EATER
03-23-2013 07:51 AM
Omicron
10-27-2011 12:37 PM
69POLARA383
08-01-2011 08:37 AM
Cracocuda
10-09-2009 05:40 PM
Cracocuda
08-29-2009 06:04 PM
Quick Reply: Billet alternator pulley
