Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > C-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 07-09-2008, 07:26 AM   #1 (permalink)
beefco
Junior Member
beefco's Avatar
C-Body Front Gas Shock help
OK. This is probably a dumb question but here it is. Back in 1983 I installed KYB shocks. I want to put in a new pair because I think they could use it. I don't remember it being an issue then. But hey I am also 25 years older now. I can't get them out to put in the new ones. I can compress them for a short period of time but not long enough. What is the trick. They are too thick to drop through the control arm but there is not enough room to move them to the side and out. I am not inclined to drop the ball joint or something either. I thought about drilling a hole in them to relieve the gas but.... I don't know about that. I am doing this on my back in a driveway. Any ideas.
beefco is offline   Reply With Quote
Old 07-09-2008, 06:12 PM   #2 (permalink)
413
Member
413's Avatar
Have you jacked the car up and left the suspension hang free? That may give you additional room.
413 is offline   Reply With Quote
Old 07-14-2008, 08:12 AM   #3 (permalink)
beefco
Junior Member
beefco's Avatar
Yes
Old 07-15-2008, 12:10 AM   #4 (permalink)
413
Member
413's Avatar
Can you compress them and have someone tie some wire on them to keep them from extending. Sounds like they need to be compressed as far as possible to get them out.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
WANTED: ram shell or front end Liu Kang Dodge Ram 1 03-25-2008 07:13 PM
Front end rebuilt Crsher B-Body 1 03-19-2008 03:50 PM
Dodge getting too much gas theaspenator Do-It-yourself Section 9 02-01-2008 08:46 PM
Front axle housing seals Jonah Hex Dodge Ram 1 10-17-2007 05:14 PM
'73 Dart Front Torsion Bar Install, Queens NY krsboz A-Body 0 09-23-2007 10:10 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
