Carburetor Question
1969 Fury III 318 Auto:
Replaced the original Carter BBD 2-bbl with a nice rebuilt identical carb; starts fine but does anyone know the proper adjustment specs for the fuel/air mixture screws? I backed both out from seated to 2 1/2 turns & the exhaust stinks of raw gasoline. Forgive my ignorance on Carter carbs, is the fuel adjustment on the passenger side or driver side? Info on these little Carter's have been impossible to locate. Thanks for any insight as always. |
First make sure the timing is set first. If you are running points, the order is:
1 point gap, dwell 2 timing 3 idle speed/ mixture/ idle speed/ mixture as needed 4 After idle mixture is proper, then touch up idle speed if necessary Either get a tach or vacuum gauge or both. Warm the car completely up, and be sure the choke is fully open. Adjust the screws first one, then other, repeat, wrench, repeat, for max idle speed or highest vacuum, then screw IN (cw) until idle speed just "starts to not drop." In other words, the "lean" side of the peak. You'll have to adjust the idle speed, if they are off very far. |
It's a 2 bbl one mixture screw for each side If it is really rich I would check the float adjustment
Originally Posted by TVLynn
(Post 83708)
