Hard start question
Old 03-16-2015, 07:42 PM
73landyacht's Avatar
Hard start question
I have a 73 Newport that has a hard time starting when cold. It takes 20 or 30 pumps of the gas before I can hear fuel coming from the jets. I thought it might be the fuel pump, but the problem remains after I replaced it. The car starts up right away when it is warm. Is this a carb issue? Or is there something I'm missing? Any suggestions would be appreciated. Thanks!
Old 03-17-2015, 07:47 AM
66300convertible's Avatar
Hard Cold Starts
I had the same problem with my car, and I believe it is because of the lower flash point of modern gas. The 4 bowl vents of the 4 bbl carb on my car's 383 let the engine heat evaporate all the gas out overnight. You can definitely smell it, and a long crank is required to pump it full again, especially if the tank is under half full. A new fuel pump didn't help me either.
I have sold my car, but I think an electric FP would have solved it. I simply primed the carb manually after it had been dormant a couple days.
Also, the car ran much better on no-ethanol (marine) gas. Doesn't help the evaporation, but it's better behaved otherwise.
Old 03-17-2015, 08:26 AM
Thank you for sharing that. Other things I read online indicated the same thing, but I wanted to see what people on the forum experienced. Based on how the car runs once it starts, it probably is the gas evaporating. Not much we can do about that I guess, huh?
Old 03-17-2015, 10:01 AM
DDodger's Avatar
I finally went EFI. Before that the most effective strategy I found was
rear mount electric pump
carb heat isolator
depending on location, block cross over
build yourself a vapor return system using wix 33040 or 33041 filter
Old 03-20-2015, 07:06 AM
moparted's Avatar
bad accelerator pump
Old 05-08-2015, 05:53 PM
moe7404's Avatar
one thing i found is let the fuel set for 10-20 seconds before cranking.
Old 05-08-2015, 11:29 PM
Do you park on a hill ? Just get a small electric pump to supplement the mechanical one... A small airtex or ?? should be cheap. Wire in a relay & switch to operate it.. http://www.ebay.com/itm/Electric-Fue...5af50c&vxp=mtr
Old 05-09-2015, 04:24 AM
Archer's Avatar
73 -
I know this is an old post, but is it possible that your choke isn't functioning properly? If the choke isn't closing adequately, you'll have problems with a cold start, and be fine with a warm start.
A-Mac555
08-26-2014 10:53 PM
jbda
04-01-2013 10:22 AM
mblackmon
05-17-2012 12:12 PM
HemiSilva
05-27-2009 02:03 PM
deadkelly
08-09-2008 08:28 PM
Quick Reply: Hard start question
