Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > C-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 06-29-2008, 02:57 PM   #1 (permalink)
ninjafury
Junior Member
ninjafury's Avatar
HELP! my fury won't idle all of the sudden
I have a 66 fury III with a 318 poly. It is my daily driver & up untill today it ran well. I recently replaced several parts, did a full tune up & I have been driving it daily without many problems. I did have a problem with the connections going throug hthe firewall but I have solved them. The car has great spark, it's getting fuel & I don't think the timing chain slipped. It will start & run great if I keep the RPMS up but the second I let my foot off the gas it dies! I'm am out of ideas. Anyone?
ninjafury is offline   Reply With Quote
Old 07-02-2008, 01:57 AM   #2 (permalink)
413
Member
413's Avatar
Is your choke stuck ? Semi blocked jet? Is the carb a Holley? blown power valve?
Sounds like carb problem.
413 is offline   Reply With Quote
Old 07-02-2008, 02:56 AM   #3 (permalink)
Doc
MasterDebater
Doc's Avatar
Did you do anything to it just before this prob started?
Doc is offline   Reply With Quote
Old 07-02-2008, 05:08 AM   #4 (permalink)
naughtyus maximus
Junior Member
hi
it sounds like a vaccum pipe to me
naughtyus maximus is offline   Reply With Quote
Old 07-02-2008, 06:46 PM   #5 (permalink)
Doc
MasterDebater
Doc's Avatar
UNLESS it is not a plugged idle circuit in the carb .... a broken vacuum line sounds like what it is.
Old 09-18-2008, 11:22 AM   #6 (permalink)
rockeralan
Junior Member
Wink
totally agree with the vac pipe theory, this coupled with the extra air getting in through the vac pipe would cause a very VERY lean mixture and no idle , rev her up and it will richen up and run , l think you're spot on , anyone got a right hand rear fender arch trim for a '69 Fury lll convertible ?
rockeralan is offline   Reply With Quote
Old 09-18-2008, 01:15 PM   #7 (permalink)
Commando
Senior Member
Commando's Avatar
That is that same issue I am having with my 400, vacuum leak. You may want to do what I am inprocess of doing, trace your vacuum lines and run a propane torch unlit over the lines to see if the idle changes, when it does there is your leak, also run it over the gaskets on the intake and the carb. Hopefully you find your leak, if not you are in my boat and I am still trying to track down the leak.
Commando is offline   Reply With Quote
Old 09-18-2008, 02:05 PM   #8 (permalink)
67 GTX
make sure your idle circuit isn't clogged
67 GTX is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
75-78 Fury/coronet/monaco jiminwatford B-Body 5 08-10-2008 06:27 PM
1971 grancoupe Fury soulkithchen63 General Discussion 2 04-06-2008 08:52 PM
I have a few questions about my 66 Fury III. team39763 General Discussion 5 01-20-2008 06:42 AM
2001 Neon Idle Problem Newf General Technical Questions 0 06-22-2007 10:44 PM
1969 Plymouth Fury 3- - -HELP!!! DJDirtyStyle C-Body 2 05-27-2007 11:21 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
