Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > C-Body
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-22-2008, 08:13 PM   #1 (permalink)
63Fury318
Junior Member
Exclamation HELP.. someone pulled my DIST caps off
Someone please give me a link to a diagram to match my firing sequence.
I have my 63 Fury 318 manual with firing sequence of 18436572
but I do not have a diagram showing where #1-8 is on the engine as well as where #1-8 is on the cap.
I've been looking for an hour on google and have gotten only that the numbers go in COUNTER CLOCKWISE on the DIST but that does not help me if I do not know for sure which engine connection is which.
Please help as I am staying the night here until I get this fixed correctly.
Please email me as well as replying here in case I do not get notified when there are replies.
If you have a diagram but it is not online then you can just email me an attachment pict or whatever to (tf AT frentzs.8k.com)
thank you for any help any of you can be,
Tim
63Fury318 is offline   Reply With Quote
Old 08-22-2008, 09:54 PM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
Dist caps ?...??? Do you mean someone pulled your plug wires off ?
Doc is offline   Reply With Quote
Old 08-22-2008, 10:07 PM   #3 (permalink)
Commando
Senior Member
Commando's Avatar
I assume that it must be the wires, as the cap only goes on one way.
Commando is offline   Reply With Quote
Old 08-22-2008, 10:24 PM   #4 (permalink)
Doc
MasterDebater
Doc's Avatar
Roger that ... 63 ... are you able to determine #1 TDC .... ??
Old 08-23-2008, 07:07 AM   #5 (permalink)
ef8340
Senior Member
ef8340's Avatar
remove no.1 plug and bump the ignition while using your thumb to cover the plug hole when the comp. blows your thumb off the hole that should be where no.1 is on your distributer check on your timing mark on the balancer to see if the line is close to the marks when everything is lined up wire acording to the firing order no. casted onto your intake
ef8340 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
