Instrument gauge voltage limiter
Looking to get my instrument gauges working.
I pulled the instrument cluster and cleaned all the board contacts. I found a condenser attached to the housing and to post "S" on the gas gauge/pcb. I did not find a voltage limiter mounted to the cluster. I assume I need an IVR4 voltage limter attached to the cluster (is this correct??). How would it be wired ( I don't find anything in the schematic that showns the limter). Any help appreciated! Thanks |
If you search you'll find many DIY conversions.
http://www.allpar.com/history/mopar/electrical2.html |
Look up #7 on the Allpar link
