Question regarding a 68 fury II
Old 04-10-2015, 08:17 PM
  #31
Originally Posted by 68fury
Btw I didn't say anything before but this is perfect, I wish they went into a little more detail on the pricing of their various tiers of engines. I'm on a college student's budget
It only takes a phone call.... Mike has many Combo's to choose from.... Great guy to talk to when your close to buying something... If nothing else just call him and see what he might be Blowing out on sale at that time... Tell him I referred you... Really!! ...
Old 04-10-2015, 08:48 PM
  #32
68fury's Avatar
I'll call him for sure, maybe I can get something a little less expensive. I'll be sure to mention you
Also I'm curious, I've heard that the transmission on my fury (the 727 torqueflight 3speed auto) can only handle small blocks, could it handle a 340? It currently has a 318 but if I were to upgrade I'd love the 340.
Old 04-11-2015, 06:09 AM
  #33
Yes... Just an FYI... The Small Block and the Big Blocks on Chrysler Products use different Bell Housings for there engines...
Small Block Housing for Small Blocks
Big Block Housing For Big Blocks
If you wind up needing a transmission? CRT is My Choice... http://coperacingtrans.com/
Old 04-12-2015, 05:55 AM
  #34
68fury's Avatar
We are currently exploring options to get the oil slinger nice and snug, so far no progress has been made because I've been working 12 hour shifts.
I wanted to check with you guys, would putting washers next to the slinger to make it fit be a bad idea? I'm not really sure how the engine would tolerate that.
Old 04-12-2015, 06:32 AM
  #35
I dont think I would do that.... The problem just needs to be fixed correctly....
Old 04-12-2015, 12:01 PM
  #36
68fury's Avatar
I thought so, just needed to be sure.
Old 04-16-2015, 01:30 PM
  #37
68fury's Avatar
Hey guys, been away for a little while. I guess what happened is when I ordered a new timing chain they sent me a double roller instead of a single. It still fits and runs but prevents the oil slinger from seating correctly.
I read on mopar chat that double rollers dont need oil slingers but that was for 440s. Not 318s.
Thoughts? Should I leave it alone? Take off the oil slinger? Replace the timing chain?
Old 04-16-2015, 06:40 PM
  #38
This Small Block has a double Roller and a Slinger??????
https://www.google.com/search?q=Mopa...D2%3B640%3B480
Old 04-16-2015, 07:34 PM
  #39
68fury's Avatar
Yeah I see that, is that picture upsidedown? On mine the big cog goes on the upper slot.
Are there any modifications I should make to make it sit right? On another forum someone mentioned something about drilling a new hole in the block or something.
Old 04-17-2015, 06:12 PM
  #40
68fury's Avatar
Thanks for all your help you guys, the problem has been solved! You were All very helpful and I appreciate it
Old 04-17-2015, 09:19 PM
  #41
moparted's Avatar
solved how?
Old 04-21-2015, 02:14 PM
  #42
68fury's Avatar
We tightened the lower crank bolt correctly and everything kind of fell into line
1966DartConvertible
10-31-2011 07:53 PM
MoparMan76
04-03-2010 03:20 PM
67sportsfury4-speed
01-31-2010 10:44 AM
BuckingStockBroker
06-26-2009 08:19 PM
bighoss1999
04-21-2008 02:11 PM
Quick Reply: Question regarding a 68 fury II
