&0 AAR Cuda Exhaust headers & heads
Old 12-17-2014, 12:58 PM
CudaBob's Avatar
Newbie, 70 AAR Cuda with correct heads, headers on it are sooo rusty you can poke your finger through, are the heads exhaust ports the same as other 304 heads? looking to find a replace set of headers?
thanks for your help
Old 12-17-2014, 03:09 PM
John Van's Avatar
I do believe all la small blocks have the same exhaust ports locations, I recommend the Heddman Elite headers, as they have thicker flanges and tubes.
john
Old 12-17-2014, 04:33 PM
moe7404's Avatar
BIG HINT: ALL WAYS use anti-seize compound on ALL bolt threads in ext systems. on cast iron manifolds. tighten bolts to 70-80% of full torque at first. then after 5-7 full heat cycles take to full torque. but check with the header experts for doing headers. one exception is slant 6 manifold. its torque processe is much diff.
Old 12-17-2014, 08:38 PM
There are exceptions but 98% are the same W2's are different
aarcuda7954
09-07-2014 06:58 PM
408duster
06-09-2011 11:28 PM
rabys
09-14-2008 04:05 PM
rabys
03-22-2008 11:37 AM
rabys
11-25-2006 08:46 PM
Quick Reply: &0 AAR Cuda Exhaust headers & heads
