Breaking up
Hello ,I have 340 ralley Challenger,now it has 440 4spd usded stock Elc ignition for a 73 car my problem is car runs poorly ,feels like ignition problem everything is new motor is 1976 rebuilt , Iwas checking voltage from battery to ballast resistor only have 10 .4 volts ,wondering if it needs a full 12 , also swapped out control box car still acts the same . car also doesn't run Well with no load while driving ,if your on the gas it will stay running , but it feels like it's struggling to run ,like it's breaking up ,Vacume is around 10 pulls up to 15 to 18 when you rev it , I also changed the Distributor cap , thought maybe it had hair line crack. Any ideas ???thanks Gregg
Perform a Compression test... Lets see what that comes up with.....
My own theory is "You cant tune up and engine that has bad compression".. :) If that comes out good. Then a tune up might be in order. Check for Vacuum leaks also... Hope this gets you started Greg... |
How many volts at the coil?:)
(Post 138460)
Thanks motor only has 50 miles on it ,just really missed something in the set up thanks Gregg
OK....Check for vacuum leaks.... Try resetting the timing.... and as Iowan said. Make sure you have a good coil and voltage to it...
One other question comes to mind? Did the car ever run rite after the rebuild or within the 50 miles? Keep us posted... :) |
(Post 138802)
(Post 138464)
Wow... Now thats an odd one for the book !!!! Glad you found it...
Originally Posted by Gregg123
(Post 138819)
Well running better , this is a new one for me wiper motor must have a short ,it was drawing down my voltage it was hot just plugged in ,accidentally leaned on it checking voltage on firewall thanks for all the help Gregg
Also Check for vacuum leaks.....
You could be on to something with the cam timing. Someone might have installed it wrong... |
