Install Trans Lines
on
Install Trans Lines
I have a 73 Barracuda 318 904 and want to install new trans lines. Can I do this without moving engine or trans and if so can you give me brief description. Thanks Jay
use ONLY steel brake lines. copper WILL break off. the factory uses steel for a reason!!!! mopar most use 3/8 dia tube, but some might be 5/16. i think most have the fluid in at the rear left side. here is an EXTERANL filter, i found. have one on my 01 dak. my idea is when you put a new filter in side this one will help from having to do the inside one as often.*
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. a JX-150 for 5/16 tube. ONLY use high pressure hose. If you must. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
Rumblefish318
06-26-2013 05:24 PM
72 Challenger owner
04-18-2009 11:03 AM
whbballer48
01-01-2009 07:54 AM
