Install Trans Lines
Old 10-21-2014, 10:33 AM
Jay240's Avatar
Install Trans Lines
I have a 73 Barracuda 318 904 and want to install new trans lines. Can I do this without moving engine or trans and if so can you give me brief description. Thanks Jay
Old 10-21-2014, 05:21 PM
moparted's Avatar
they easily go in from the bottom
Old 10-22-2014, 08:17 AM
Remove exhaust and starter
Old 10-22-2014, 04:04 PM
moe7404's Avatar
use ONLY steel brake lines. copper WILL break off. the factory uses steel for a reason!!!! mopar most use 3/8 dia tube, but some might be 5/16. i think most have the fluid in at the rear left side. here is an EXTERANL filter, i found. have one on my 01 dak. my idea is when you put a new filter in side this one will help from having to do the inside one as often.*
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. a JX-150 for 5/16 tube. ONLY use high pressure hose. If you must. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
Old 10-22-2014, 05:01 PM
Yours should have 5/16 lines. 3/8 would be an upgrade... I usually use fuel inj hose if needed for carb
Old 10-22-2014, 08:28 PM
moparted's Avatar
I have done them without removing starter or exhaust
Rumblefish318
06-26-2013 05:24 PM
Slice
03-30-2010 07:28 AM
HemiSilva
07-08-2009 04:03 PM
72 Challenger owner
04-18-2009 11:03 AM
whbballer48
01-01-2009 07:54 AM
Quick Reply: Install Trans Lines
