Need to buy Radiator
I have a 1970 Challenger that came with out a radiator. I need to know what size i need. I see they offer 22" and 26 " I have a 528 hemi with a 727 auto tanny going in it. I think a three row will be good. Four may be over kill. Anyway I need the width i need to buy 22" or 26".
Thanks
Thanks
Yours will be a 26" for sure. I would spend the money on a Be Cool unit. Go to Summit Racing and look one up for your car, don't go cheap on a radiator.
Measure the opening on the rad cradle. It will tell you what rad open you should use. Rad brackets will be fun though.
Worst case he could have a chopped up rad cradle already. There is brand new sheet metal openings stamped ready to weld in, and then paint of course, in whatever size you want for these cars.
Here is a good read with detailed step by step for the big fella:
http://www.forabodiesonly.com/mopar/...d.php?t=224853
I just read that hole post and cant wait to see what happens. I just ordered a performance cooling 3 core and they say it should do 800hp with the shroud set up and there 16" fan. I'll let you know what happens with our car next time the wife hits the track. We like to hit the burn out box @ 140 and stage @ 160 then the car is hitting 210+ before we get back to the trailer. So we hook up a ventilation fan and the batt charger between passes. we want the car to run cool but in that other post they say 165 is unrealistic with a big block.
and this that I love when I built a rock crawler.
TEN COMMANDMENTS FOR MAXIMUM COOLING
1. Thou shall make room for an adequate cooling system in the design of your engine compartment.
First things first. When planning your performance vehicle, remember that you're building it to drive, not to sit and steam. Plan adequate space for the cooling system including the radiator, fan, shroud, over flow tank and mounting brackets. Talk with a cooling specialist to help you size the system for your vehicle, engine and driving habits. Consider the investment compared to the total cost of the car.
2. Thou shall shroud thy radiator when using a fan.
Fans move air through the radiator assisting in cooling the engine. A fan without a shroud is better than no fan. But, consider this. At idle or cruising speeds, you need the entire cooling system working at its optimum. An unshrouded fan is moving air through only the portion of the radiator equal to the surface area of the fan. For example, on a '32 Ford, the area of a 15.50" fan is about 189 sq. in.; the core of the radiator is approximately 371 sq. in. This means that almost 49% of the unshrouded radiator is not receiving any benefits of the fan. Shrouding your radiator lets the fan pull air through the entire core.
3. Thou shall use an electric fan.
Rule of thumb. Only choose a mechanical fan over an electric fan if it's your farm tractor. An electric fan is preferred because when you need a fan the most (at idle or cruising speeds) an electric fan is delivering maximum air independent of engine RPM's. Fans that move 2000-2300 CFM's are worth the investment. Preference should be given to a "pull" vs. a "push" fan. Mounted on the engine side of the radiator, a pull fan does not interfere with air flow at highway speeds. All shrouded fans should be on the engine side of the radiator.
4. Thou shall consider airflow or how a radiator cools.
Without adequate air flow, a radiator is just a reservoir for hot water. Coolant transfers heat to the tubes; the tubes transfer heat to the fins; air moving through the fins dissipates the heat from the radiator. You need sufficient openings to the radiator that channel adequate air to the entire surface of the radiator. You must have a radiator design that allows the air to pass effectively through the radiator (wider and taller is better than thicker). You must consider how the heat will be evacuated from the engine compartment.
5. Thou shall use the proper water pump pulley ratio.
To obtain the maximum operating efficiency rate for your water pump at highway speeds, you should overdrive the pump by 30-35%. Check your pulley selection. Most after market pulleys are a 1:1 ratio. For a 30-35% overdrive, the crank pulley should be approximately 7 7/8" and the water pump pulley approximately 5 3/4". This overdrive provides proper coolant flow from the engine and through the radiator.
6. Thou shall consider the effects of the pressure cap.
The higher rated the pressure cap, the hotter the water has to get to boil. One pound of pressure raises the boiling temperature 3°F. A 16-pound cap raises the boiling point to 268°F. If your engine is designed to run at 200°F, a 14-16-pound cap should be sufficient. Running a higher pressure cap to prevent boil over is putting a band aid on another problem that needs to be fixed. Higher operating pressure places additional stress on the entire engine system and increases the potential of hoses bursting and possible injury.
7. Thou shall understand the operating temperatures of today's modern engines.
All engines have "normal" operating temperatures. Running engine temperatures well above or below recommended temperatures could cause damage. Most of today's engines operate in the 180°-210°F range. Pollution laws, new oil blends and higher combustion gasoline have forced engine design changes that have increased operating temperatures over the past decade. Consider your engine's normal operating temperatures when selecting your radiator's cooling capacity.
8. Thou shall always use a thermostat.
The thermostat controls engine coolant temperature. It stops the flow of coolant through the radiator until the coolant reaches the thermostat's preset temperature. Operating your engine within its temperature parameters reduces wear, helps control emissions and turns any moisture in the crankcase to steam where it is removed by the PCV system. Select the right thermostat for your engine's operating temperature range.
9. Thou shall protect thy cooling system with recommended coolant.
It is essential to use a premium coolant that protects the radiator, other metal parts and seals. Today's coolants are a scientific blend that normally includes water wetter and corrosion inhibitors. Use of a coolant that contains no silicate is recommended. Silicate is an abrasive and can cause gel formation and water pump failure. A 50/50 mix of coolant and distilled water provides the best overall cooling efficiency. Proper maintenance (regular flushing and changing of coolant) will extend the life of your system.
10. Thou shall spend thy money wisely.
If you are having cooling problems, begin by looking at the least expensive fixes first. 1) Add an electric fan. 2) Shroud your fan. 3) Check your belts and hoses. Slipping belts or collapsed hoses mean trouble. 4) Check your radiator cap. 5) Flush and refill with premium coolant. 6) Use the proper thermostat. 7) Clean the radiator of foreign materials. 8) Overdrive the water pump 20-30%. 9) Check your water pump. Should cooling problems persist, it may be time for a new performance radiator from Griffin. Call the Griffin Customer Service Department at 1-800-722-3723 for assistance in selecting the correct radiator for your requirements.
** WARNING: Improper wiring can cause electrolysis and destroy the radiator. Please make sure radiator is not used as a ground. **
Mango
10-27-2010 06:32 PM
gotdust
07-09-2010 03:23 PM
