PCV Valve Connection to Carb
Hey gang,
I'm going to connect a PCV valve to my carb to complete the valve cover set up. It's a 6 pack on a 440. I'm uncertain as to which port I can use to connect the PCV though. I think I can and should use the only port that is visible in this photo at the top of the carb. I can't find any information on it any where else. Can anyone lend some advice? Thanks. https://cimg3.ibsrv.net/gimg/moparfo...3d6c04961c.jpg |
pvc
1 Attachment(s)
Center carburetor lower 3/8" nipple
Agreed.. :)
So right now the power brakes' hose is connected to that port as you can see. I've seen a configuration with the PCV connected to this port as you both have indicated. The top port I was thinking about looks like it can be used for the breather hose.
Can I get away with having a breather cap on one valve cover, and a valve cap with a hose attachment going to the carb? OR Breather on one side, and PCV to carb? What do I do with the power brake hose afterwards? |
Also, any photos of your set ups from the valve cover to carb connections?
blue -
PCV and breather should always be on opposite valve covers. Kinda defeats the purpose otherwise. Kinda easy to figure out out full manifold vac. Find a large bore port, start the engine and feel for suction. If you feel any, odds are you're good to go. An open vac post should cause a rise in rpm. Just remember, the port can be on the carb OR the manifold. Archer |
