Vacuum Leak
As some of yall may know ive got a vacuum leak, I was wondering if anyone knows anything about the hose kits on hiperformancestore.com?
There kits apparently replace all under hood vacuum lines, a few coolant lines, the line from the windshield washer pump, and the vacuum line to the heating and A/C controller. |
Are you sure that the vacuum leak is coming from a hose? It could be the intake or carb gasket.
If any of your hoses are cracked though, they could be sucking air in through those cracks. |
most of the hoses are dry-rotted, so i was gonna replace em anyway
the carb gasket needs replacing and i think ive got a bad head gasket because whenever i put the pedal down and park it after there is oil all on the left valve cover and alternator |
Is your breather filter on your left valve cover? I've seen oil come out of them before.
If your hoses are cracked, then it is a good idea to replace them all. Along with that carb gasket. |
yeah my breather hose is on the left, and it leaks really bad
im gonna order the kit sometime next week, and get a nex carb gasket |
Your going to have to figure out why you have oil coming out of your breather. You shouldn't have that at all. Even if you fix all your hoses and replace those gaskets, you could still have ol coming out.
i'll take a picture of the leak one day, put it up here and see what you think. originally i thought it was the valve covers but i guess not
are you running headers on the motor and if so can you tell if the oil is coming from the header gaskets ???? ( between the head and the header)
ive never had oil come out from the header gasket
is that possible? you would have to have bad seals on the springs wouldnt you? |
Sorry i meant cylinder head, the leak is on the left side and oil get all over the back of the alternator, bottom of the air filter and the valve cover
have to tried a compression test?
that might tell you if the head gasket is good |
I'll try that sometime this week
how many lbs should i be looking for?
and how much difference between the cylinders before i need to worry? |
if compression in 10 to 1, i think pressure is around 150? not sure though
10lb difference between cylinders is ok |
Originally Posted by 78D200
(Post 12618)
did you try a compression test?
hey yall, orry it took so long to reply...we put the smoke machine on the engine and couldnt find any leaks, messed with the timing (it was way off) and that seemed to do the trick but it still sputters a little every now and then, and i still havent done a compression test will soon though
does anyone know where i can get a breather cap with a pcv valve in it? |
i got mine off ebay
alright, thanks GTX
hey 67 when i changed oils to full synthetic i had a really bad problem if you remember as this some what started the zinc thingy on here but the FS oil was just flowing out my valve seals and was told by valvoline to change back to the VR1 oils as the FS oils have way to many cleaners in it and the VR1 has the right amount of additives in it to make it work for my engine and by the way it was like a faucet turned on with the oil pooring out my headers :) but the VR1 stoped all that
haha
i havent had any of those problems hmm, now im wondering |
