wilwood disc conversion problem
hi , i have installed now a kit with front disc drilled and caliper Wilwood 4 pistons on my 1970 Barracuda , factory brake is front disc with single caliper and rear drum , the problem is the car brakes less than before !!! , master cyl is factory Dorman 1.031 diameter , rebuilded brake booster , rear drum 10" with new shoes and new wheel cyl .. i have installed also wilwood regulator on rear brake ... nothing ! no brake !! pedal is hard and not brake !! help me !!
Yes Bob ,wilwood stainless brake hoses , wilwood brake pads .. bleeding upper ... car doesn't brake .. this car never brake also with single pistons factory caliper . this morning i changed also the proportioning valve ... no change .... i have also vacum electric pump
If pressure is good......
Try a new set of lining.... We have been having problems with MFG changing the compound of the make up of the lining and not stopping....
Some have a sign of a spongy pedal but others just say it will stop but takes allot longer......
At first I thought this was your car? Now I know it is a customers car.... The Red Car..Now I get it
Some thoughts/questions
Were the brakes bled furthest to nearest the master cylinder? ie., rr > lr > rf > lf?
Is the master cylinder/power booster pushrod releasing enough to allow the master cylinder piston to clear the vent hole?
Is the master cylinder/power booster pushrod travel sufficient to fully depress the master cylinder piston? (pressure test will tell)
Was the master cylinder sufficiently bench bled?
Is the master cylinder correct for front disc/rear drum application?ie., no built in residual valve for the front disc.
Is the master cylinder/power booster pushrod releasing enough to allow the master cylinder piston to clear the vent hole? vent ??? i dont know ! please show me !
Is the master cylinder/power booster pushrod travel sufficient to fully depress the master cylinder piston? (pressure test will tell) yes is correct
Was the master cylinder sufficiently bench bled? yes blended 3 times
When you look into the fluid reservoir you should be able to see the piston move past (to the rear of) the vent/fill hole in the bottom of the reservoir. If it (the piston) is uncovering the vent/fill hole, you should get fluid spraying up (messy)when you release the brake pedal.
yes blended 3 times
My manual master cylinder took about thirty(30) fulll pedal pumps to (bench) bleed.
yes blended 3 times
I have blended another time ..i have cheched the vent .. All is ok but the car doesnt brake ... I checked the line pressure on caliper is 1200 psi with vacum applied and 700 without vacum ... Checked also disc to calipers allignement .. Nothing .. Pedal is hard and car doesnt brake !!!! I see after 4/5 brakes .. The rotors are not very hot ...
Bob i tried now to remove the pads ... Look like glazed ... I have cleaned with sand paper 80 .. I tried to remake the break in .. Is a little bit better ... But not efficently
#28
NOW I HAVE INSTALLED THIS !
http://www.ebay.it/itm/200962698010?...84.m1497.l2649
IS DUAL 8" ... BRAKE PERFECT !! NOW IM UNDECIDED IF INSTALL OR NOT THE REAR DISC CONVERSION THAT I HAVE ALREADY BUYED FROM ssbc
#29
Wow...That's the 2nd Diffective Booster with in a week that I have heard about..... CRAZY....
Glad you found it..... So what was really wrong with it was it had "No Assist For braking"....
Thanks For the update Raffa.... You Rock !!!
By the way.. I love that White Chrysler you posted.... Awesome
#30
Yes Bob was Brake Booster diffective !! now brake is perfect ! yesterday i have check the pressure with new gauge .. is 1300 psi on the front and 1300 on the rear ----- look like ok ... thanks for your help
