speedometer
Old 07-31-2012, 05:57 PM
Gilberto Miranda Rojas's Avatar
speedometer
I have a volare 1979. The speedometer cable is 60 inch. I wonder if the cable 80-inch willfit. Where I can buy.
Thanks
Old 07-31-2012, 09:50 PM
You came to the right place. First of all no body makes a direct replacment for our cars. Get an 80 inch one for a 1980 something truck. Then you have to replace your plastic adaptor with an older aluminum one and an older style gear. I did it and it works. Go here to order what you need.
http://www.transmissioncenter.net/sp...n_______va.htm
get this cable.
Part number 4360.
Get this adaptor.
Part number 13h.
and then get one of these long shaft gears. They can tell you which one by tire size and rear gear ratio.
Old 07-31-2012, 10:07 PM
If you have the original speedo adapter those gears will not fit. That is unless you use the older style adapter. I would check with a speedo repair shop.. They should be able to make a cable the length you need
A quick search turned up this http://www.speedometersolutions.com/...eter_cable.htm
Old 08-01-2012, 09:58 AM
I did this on my F Body and it worked like a champ. It had a shorter cable and a plastic housing and plastic gear that I sold to someone else. He would have to buy all three pieces that I mentioned above. When you change tire size such as I did I had to source a new gear and good luck with finding one of those plastic ones for the plastic housing.
Old 05-17-2015, 04:57 AM
volarerr340's Avatar
also better with the older style since the gears are more available.
stazja01
11-07-2012 12:21 PM
DUCMAN166
12-21-2008 07:49 AM
gotdust
04-27-2008 10:31 PM
wheelman487
04-24-2008 04:58 PM
wheelman487
12-04-2007 07:49 PM
Quick Reply: speedometer
