1955 job rated 1/2 ton pu
anyone know how to tell the difference between the trucks such as c1b, c3b? mine is a flat 6, 3speed manual on the column, 2 wd, it has a 6 volt system and it has the job rated logos on the fenders. thanks for any help.
I used to drive a '54 1/2 ton. Factory 318/granny 4spd. with a 6 volt system.
What did you want to know? An old ad for a C3: http://www.oldride.com/classic_trucks/278732.html An ad for a C1B6: http://www.hemmings.com/classifieds/...b/1127940.html It may be as simple as the C1 was a 6 cylinder and the C3 had a V8. |
thanks, i was able to find out it is a c3. all i had to do was clean off the vin plate under the hood a little better thanks
