'68 Dodge P-300, anyone have info?
Old 11-01-2014, 09:38 AM
Spitfire's Avatar
Greetings all, I just made the purchase of a lifetime. the ugliest vehicle I've ever seen, but i love it. I was wondering if you guys had any service info or any background on it. it has a 225 six, dana spicer rear (dually too) and a 4 speed, unknown make. the only thing i need parts wise at the moment is a very rare six lug rim. anyone with history on these, please, chime in. thanks guys.
Old 11-01-2014, 11:22 AM
Oh come on, even a mother can love an ugly baby.
1st: http://www.hamtramck-historical.com/...-3%20page2.jpg
From my Motors Truck Manual.
8.4 compression (145psi) 140 hp at 3900, 215 tq at 1600.
Plug N11Y or N6 for 225-2. Point gap .020, dwell 40-45, timing 0 or 5 BTDC. Fuel press. 3.5-5.
Caster (no load) 1.5, camber 2, toe-in 0-.125, king pin incline 7 degrees.
Valve lash Int .012H exh .024H
Big guess on transmission, New Process 420 or 435.
Old 11-02-2014, 07:44 AM
Spitfire's Avatar
thank you, the trans code is the NP 435. i got her to turn over, but it's been sitting for a while. needs a brake overhaul, which isn't terrible. trans still moves between gears, clutch still actuates, and the starter sounds healthy. no knocking yet, i havent given it fuel either. but the radiator still has coolant, and it's still green. all in all its worth what i paid. it also has the old UPS logos on the inside. it's a cool old piece of history, and i'm glad to have another mopar to work on.
Old 11-02-2014, 04:25 PM
moe7404's Avatar
if its been setting a while. pull the spark plugs and put 2-3 oz of marvel mystery oil in each cyl. and turn it over before you put the plugs back in. and use some air in fuel tank carefully , slowly, to get fuel in the carb. and when it starts take the RPM a little higher than idle. to get oil on the cam.
Old 11-04-2014, 03:37 AM
Any pics of it?
The rear axle is probably a dana 60. The NP435 tranny is one of two versions (either with a 6.68 or 4.56 - you'll know when you drive it).
Spitfire (11-24-2014)
Old 11-24-2014, 04:35 PM
Spitfire's Avatar
it's gotta be the 6.68, that thing crawled with rpm, which is nice, i plan to use it as a heavy hauler, within reason. i got it running, i drained the old gas out, put fresh gas in, and spun it until it picked up fuel. by then it got oil to the top end, and i made sure to give it rpm for the cam, again, within reason. i have to find a rim though. it's a six lug, but the hole spread is in the 8 inch spread realm. i've never seen one like that.
Old 11-24-2014, 04:36 PM
Spitfire's Avatar
also unsure how to post images. working on it. brace yourselves, it's very Jeepers Creepers.
Old 11-24-2014, 04:42 PM
Cool !!!!!!!
Old 11-24-2014, 04:50 PM
Spitfire's Avatar
[IMG][IMG][IMG][/IMG][/IMG][/IMG]
Old 11-24-2014, 04:51 PM
Spitfire's Avatar
there's the album, i sorta got the hang of it now.
Nathan89
08-15-2017 12:10 PM
69POLARA383
02-22-2012 05:54 PM
Rturn
10-07-2011 11:12 AM
ntcongia
07-25-2008 08:38 AM
71charger
04-02-2008 05:22 AM
Quick Reply: '68 Dodge P-300, anyone have info?
