Question on spread bore Holley installation
Hi,
I have a Holley 80555 GM Spread bore carb that I need to install on a 1973 Chrysler 383 Spread bore manifold. How should I set the throttle linkage up so that it will work with my 1973 Dodge D200 2wd? The engine is a 400 6.6L. Is there an adapter for this setup? Thanks, Dave |
I'm sure that rickyr will chime in as he works for Holley and should be able to answer your question.
That would be great. So far I am suspecting that I will need to use a spacer to raise the carb up a bit, and that there is no Chrysler linkage adapter made for spread bore holley carbs, only square bore.
