fuel tank sender for 53 plymouth
Old 08-05-2015, 07:45 PM
53bob's Avatar
Question fuel tank sender for 53 plymouth
1. Have leak in fuel tank so removed the tank but how is the sender removed. Seems like a screwdriver on the cogged collar might work but nothing moves. Any suggestions?
2. Am switching from 6V pos ground to 12V neg ground. Do I need a 12V sender? Or will the existing one work??
Old 08-06-2015, 02:02 PM
Should be able to move remove the collar....
Sender should be ohm's if using the same gage.... Should be fine..
Shrug
10-10-2013 10:20 PM
53cranbrook
01-11-2013 06:31 AM
Shrug
06-09-2012 10:27 PM
71_Duster
04-29-2010 07:34 PM
mopar528dakota
06-17-2008 03:58 PM
Quick Reply: fuel tank sender for 53 plymouth
