Go Back   Mopar Forums > LATE MODEL REAR WHEEL DRIVE/4WD MOPARS > Dodge Ram
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 09-19-2007, 02:19 PM   #1 (permalink)
tbreaden
Junior Member
89 W-250 TBI to Carb?
I have a 89 W-250 I am going to switch from Fuel injection to carb. I am changing dist. and putting on a 600 Edelbrock carb. My question is about the in tank fuel pump. Should I run a regulator with bypass or can I add a inline electric fuel pump and will it pull fuel through the in tank pump if not hooked up? Thanks, Todd
tbreaden is offline   Reply With Quote
Old 10-10-2007, 11:19 AM   #2 (permalink)
1 Bad Mirada
Administrator
1 Bad Mirada's Avatar
interesting...im not sure if there is anything to prevent the inline electric filter from drawing through the stock filter...
1 Bad Mirada is offline   Reply With Quote
Old 11-05-2007, 03:16 PM   #3 (permalink)
SixtySixDeuce
Shooter
SixtySixDeuce's Avatar
You'll have to remove the in-tank pump and install either an in-line electric or conventional mechanical pump. The TBI pumps run 5 times the pressure an Edelbrock carb can take.
__________________
Wanna make those folks with the rice rockets close thier mouths? Just mention the word "torque" and watch them shrink away.
SixtySixDeuce is offline   Reply With Quote
Old 01-17-2008, 06:36 PM   #4 (permalink)
CAT-TECH
Member
CAT-TECH's Avatar
Ive heard of guys still running there in tank pumps but just "unplugging" them and runing a inline electric fuel pump, I really dont know if it works though...
CAT-TECH is offline   Reply With Quote
Old 01-20-2008, 02:18 AM   #5 (permalink)
hillbillyape
Junior Member
I have an '88 318 that had TBI. I installed a cast 4 barrel intake. You may have to remove the intank pump and lengthen the pickup tube and screen .I don't think it will draw throught the pump. My engine is in a '63 panel using a different tank. My big problem is the distributor. My engine has a hydrolic roller cam, yours may not, but I cant find a dist that will work. An older point type dist is 7/16" too short and will not engage the drive gear. I'm still looking for answers.
hillbillyape is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
