fuel lines and proper fittings
Hello
It's been awhile since I've posted I'm doing research for a possible efi magnum swap w/ megasquirt project this summer. My questions are for the 96 to 03 model trucks.
I tried searching for them by application (96-03 Dodge RAM 1500 or 2500 5.2 or 5.9) but, I'm not really finding anything solid that says it works for or is for those applications. In fact, I'm finding it kinda of difficult to locate pictures of the fuel rail itself but, from what I've seen so far it doesn't look like it uses a hose barb or standard fuel fittings. Some look like they have a male connection, some look female... But, surely you must be able to buy something? how would you repair them if the line was damaged? I read a page here that said some of the quick connect fittings Chrysler where similar to gm ones. Below is the closest thing I could find but I'm not sure if it works but it's listed for Chrylser 1988-2003 https://www.dormanproducts.com/p-16447-800-057.aspx There even seems to be different fuel systems setups (return vs returnless)
Any help would be awesome. Thanks https://cimg7.ibsrv.net/gimg/moparfo...71b7e7357f.png https://cimg9.ibsrv.net/gimg/moparfo...60431b49b5.gif https://cimg0.ibsrv.net/gimg/moparfo...60f916f65c.gif |
https://www.summitracing.com/parts/rus-640930
https://www.summitracing.com/parts/rus-640863/ I wonder if these would work? They are 5/16 and there are also 3/8 variants available. To be honest I'm probably getting ahead of myself with small details like this without actually having a magnum engine to look at but, it would be nice to have it figured now so I don't have to think about it later. |
If the fuel rail was female?
https://www.summitracing.com/parts/pfs-52180 There we go. Size is 3/8 Connects to late GM or Chrysler fuel inlet line on most fuel injected applications. So.. perhaps something like this if the fuel rail is male? https://www.dormanproducts.com/p-9569-800-082.aspx Also, found a another pic of the stock male fitting. Rolled bead with crimped hose on the other end. I wonder if I could just have a hose shop make that? But, does it transition to steel lines at the frame? https://cimg5.ibsrv.net/gimg/moparfo...fac8cad68a.png https://cimg8.ibsrv.net/gimg/moparfo...e213f74be7.gif |
