p0004 code
Old 07-21-2012, 07:39 PM
levi's Avatar
p0004 code
Ok guys i need some help. I pull this code off my truck. I've found a lot of info. Of what it is. but nothing on how to fix it. I've got an 08 2500 with a 6.7. I've tried to clear it. But still there. Surely someone has an answer. To my problem
Old 07-22-2012, 03:26 AM
P0004 - Fuel Volume Regulator Control Circuit High - Sound about right? If so then the pump or regulator are trying to dump more fuel in because the computer believes that the motor is running lean. I'd start looking for vacuum leaks and go from there. Other than that, I'm really no help as I don't know that much about diesels.
Old 07-22-2012, 03:32 AM
Another possibility is that there is a leak in the fuel line somewhere.
If you can/want, the dealership actually has books on vehicle specific diagnostics that cover all the codes. Might be some money but might also be something to invest in as they explain what the code is and how to diag it.
levi (07-22-2012)
Old 07-22-2012, 07:18 AM
levi's Avatar
thanks
i'm taken it to a dealer. i'll post my results
ngc414
01-11-2021 01:50 PM
azcuda
Cuda Specific Discussion
07-13-2009 08:55 PM
Skunk Ape
02-03-2009 01:28 PM
Red Devil
12-23-2008 07:58 PM
plowman
04-28-2007 10:39 AM
Quick Reply: p0004 code
