Oil pan swap
Old 07-29-2009, 05:25 AM
Polaradude's Avatar
Oil pan swap
My buddy has a Durango and we are going to change the oil pan this weekend. What I am wondering if there is any easy way to do this ? Has anyone done the swap ? I am hoping the motor doesn't have to come out to do this but at first glance it looks ugly. Tips/Tricks ? Thanks in advance.
Old 07-29-2009, 09:36 AM
The only pain is going to be getting out past the bottom of the tranny. You shouldn't have to pull the motor to do it, but you may need to unbolt the tranny mount and lift it a little.
Old 12-23-2009, 08:46 PM
blue 68 gts's Avatar
Don't quote me, but i believe you have to unbolt the motor mounts, and support the motor to get enough clearance.
Old 05-26-2010, 09:49 AM
Old As Dirt
Sgt. Veteran's Avatar
Crappy thing is everyone I have done no matter what it was the motor had to be raised because of the oil pick up tube, I have dropped the pan and removed the tube and got it out but was a real pain putting it back together, torque wrench did not fit in there well. Good luck man, Jake
Old 03-23-2017, 10:16 AM
MoparMonster's Avatar
Hey Polaradude, I've done them too. (Tom, mechanic at Susquehanna CDJR.) The other guys are right. You have to unbolt the motor mounts to lift the engine just a bit. It isn't impossible, by any means, but takes a little more time. Half the battle is knowing you have to do it and making sure you have planned a few hours. Good luck.
MarkyMark12345
04-10-2009 06:43 PM
dzltd02
10-28-2008 08:25 AM
oilplanet
03-29-2008 11:08 AM
robertoil
01-25-2008 05:34 PM
Quick Reply: Oil pan swap
