concerned about new vibration
Old 12-17-2014, 02:34 PM
mopartruck's Avatar
hey everyone
I have a vibration question (again it seems) I am not sure how well balanced these 4.7's are but mine has a knocking type vibration that is there most of the time it is like a hammer tapping that goes faster as I accelerate. It is there predominantly when in gear and the engine is under load. If I take it out of gear or depress the clutch while driving, the vibration diminishes greatly.
I have recently changed tires which helped some of my other issues and I changed the exhaust (which I checked and it is not hitting anything.
the other strange thing was today in the driveway, the front developed a kind of shimmy - it felt like it was going through the shakes. I did have it into Dodge in the fall to check the driveshaft and everything checked out ok.
This has me rather concerned as it is my only mode of transportation
Any ideas thoughts or suggestions on what this could be would be greatly appreciated.
thanks
Sean
mopartruck's Avatar
almost forgot - 2006 4.7 slt extended cab 2wd -
thanks
Old 12-17-2014, 02:46 PM
Got a wrist pin knocked out of it in the motor?
Old 12-17-2014, 03:10 PM
mopartruck's Avatar
ok - I am going to sound stupid - can you explain what that is?
thanks
Old 12-17-2014, 03:40 PM
Make sure it is running on all 8 cyl
Old 12-18-2014, 06:08 AM
Connects the rod to the piston...
Old 12-18-2014, 01:16 PM
mopartruck's Avatar
would I notice that whether it was in gear or in neutral? I also read somewhere that it could be loose or broken exhaust stud -?
thanks
Sean
Old 12-18-2014, 07:29 PM
Post up a good video.... Maybe we could get a better idea on whats up???
Old 12-19-2014, 08:29 PM
Make sure the flex plate bolts are tight
Old 12-20-2014, 01:34 PM
pro-tech's Avatar
The 4.7L engine also has a problem with dropping valve seats and it causes a knock and miss-fire...Bill
Old 12-20-2014, 07:26 PM
mopartruck's Avatar
two questions- is the flexplate in with the flywheel and clutch?
and can I check the valve seats from above or will i need to remove the head?
thanks everyone
Sean
Old 12-21-2014, 05:36 PM
Mr.4spd's Avatar
No, flex plate is automatic, flywheel is stick.
Old 12-22-2014, 10:36 AM
mopartruck's Avatar
thanks - that is what I thought - can I ask another stupid question? I just installed a new muffler and pipes - it is a little louder (Hooker aerochamber)
the more I listen the more the pounding sound is like a loud pulsing/hammer tapping type sound - could that be the way the exhaust is distributing the sound note?
I would have thought this more but I can feel the vibration in the stick which makes me wonder
thanks very much everyone
Sean
maca
08-21-2012 06:17 AM
Drakovich
11-28-2011 04:17 PM
chezhed
07-18-2011 03:11 AM
c011699
04-11-2010 03:27 PM
bochyhawg
02-05-2009 12:43 PM
Quick Reply: concerned about new vibration
