intake and spark plug
hey everyone
I had 2 similar and unrelated questions 1 - does anyone have an opinion on a best spark plug for the 4.7 motor? I have heard numerous arguments for either copper or the newer iridium(?) anyone have a good experience with either? 2 - does anyone know how important it is to keep the resonator box on the intake - I understand it give a chamber for air to bounce into and even out and to quiet things. It sounds useful, but many of these "CAI" systems seem to want to remove them. I was just wondering if anyone had an opinion on that too? thanks again for all the help you give - it is greatly appreciated Sean |
I use NGK in those...
Keeps the noise down.. |
thanks - are the ngk a standard copper plug?
resonator serves no real purpose besides noise? thanks Sean |
I was thinking of removing the resonator part for a cold air type intake, but if it does not interfere with air flow, I may just add on from there with smooth pipe and bends.
I watched some video on those E3 plugs which was pretty interesting - but $6 plug is pretty steep. |
Not needed.... Use a Std replacement NGK U Groove will work just fine....
You can do a fresh air intake it you like.... Not going to make that much more noise I dont think.... But thats just my 2 cents.. |
well it's an appreciated 2 cents - I used ngk and champions on the Porsche I used to work on - I know they worked well in that
thanks again |
