Dyno Session
Dyno Session
Just got home from the dyno session and still have the WAG on my face.. After 14 or 15 pulls we have a well broken in 6.1 hemi that is making app 600 hp and 483 ft lbs of touque... We made several timing changes thru the session and made more HP every pull.... We also learned we may need some stiffer valve springs.. Starts to float at app 7500 rpm...
We pulled the oil filter at mid point and it was perfect!!!!!! Clean as it could be!!!!!!!
Next step is to pull the pan and check some rod bearings and then install it in to the car and lets make some more noise and bark some tires!!!!!!! May then need a new cam shaft or ???? Have a video and some pictures will have to wait to up load.. Maybe later tonite or in the morning.... More later!!!!!!
rixrunner
03-28-2010 06:54 AM
