Go Back   Mopar Forums > LATE MODEL REAR WHEEL DRIVE/4WD MOPARS > Viper / SRT-10 Ram
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 04-28-2008, 12:19 AM   #1 (permalink)
jane1043
Junior Member
Copying and burning of DVD
Some time ago, a friend bought a DVD burner, and he wanted to copy a few classic DVD-video discs. However, the problem that DVD can not be copied successfully comes out when copying DVD with nero 7.0, so he asked for help.
In fact, it is known that not all the DVD can be copied simply. For the general DVD data discs, it is very easy to backup the information of DVD with Nero 7.0. Just following the step by step instruction, the copying task will be done. If you are still not very clear, please get more detailed information at http://www.nero.com/enu/support-nero7-tutorials.html
But some DVD are encrypted and protected by means of CSS. At the moment, you have to do something for crack. Choosing free software or not is up to you, such as DVDFab HD, DVDShrink, and DVD43.
The passage is prepared for the beginners. Now, Take Pavtube DVD Copy as an example. There is not so much software that supports both copying and removing CSS while Pavtube DVD Copy is good choice, which can be valid for 5 times within the first month if you use trial version.
Operating Pavtube DVD Copy is very simple and easy. See the screenshot below.
If you just want to rip some chapter, just tick it and then it will be done. Want to copy the full disc? You can choose “Full Disc” mode to complete the copying task.
Here is the guide for how to copy DVD to a blank DVD.
First make sure that you have installed DVD+/-RW.
There are two steps during the copy process: first it will copy the DVD movie to a temporary folder on your computer, second copy the files in temporary folder to the blank DVD disc.
When the first copying process is done, eject the original DVD disc and insert a blank DVD disc, click "ok" on the pop up diallog box. Then it will start to burn the DVD movie to the blank DVD disc. Now you can enjoy your copied disc!
Get more information here: http://www.pavtube.com/dvd_copy/guide/
Note: Please make sure that there is enough space (at least 5G on the hard disk) to store the folder used for the conversion process.
jane1043 is offline   Reply With Quote
Old 04-30-2008, 01:29 AM   #2 (permalink)
jane1043
Junior Member
Hope this can help you Good luck
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to copy *.vob files on DVD to the hard disk and merge them together jane1043 Viper / SRT-10 Ram 0 04-24-2008 07:38 PM
How to Extract and Ripper and Backup DVD and VCD Quickly jane1043 Viper / SRT-10 Ram 0 04-16-2008 12:35 AM
WELDER - Lincoln 175 mig-pak DVD instructions? lantzn Do-It-yourself Section 1 12-23-2007 05:12 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
