Another AMC
Old 03-12-2010, 03:35 AM
1OldFordMan's Avatar
Another AMC
Thought I posted here already. Guess maybe not. Have an AMC Eagle wagon. Pics. under Member's rides. Currently stock, soon ( hopefully ) to be AMC 360 powered.
Old 04-08-2010, 04:49 PM
old tired rebel's Avatar
How do you like it so far?
Old 04-17-2010, 10:30 AM
Haven't been here in a while. Just saw this question. Can't really answer, haven't got it on the road yet. After 1½ months at Tech School for a valve cover gasket ( had an aftermarket valve cover, required special bolts & the rear one was a pain in the @55 to get to ), it failed inspection yesterday. Have to get some stuff fixed & take it back. Even better, the valve cover leak was only part of it. Also has a rear main leaking. Tech School won't even touch that. Called the shop where I take stuff for inspection & they said 5½ hours labor ( 4wd , they have to pull the engine ). If I pull that out, I don't want to put it back in. Want an AMC 360 I paid for & now can't contact the guy.
Old 05-09-2010, 07:38 PM
Found out from the Sheriff's Dept. where the guy I paid for an AMC 360 is that he is on the run & warrants are issued . House was foreclosed end of March. Appears he was mixed up in dope . Sadly am stuck with the 258 for a while .
Old 05-09-2010, 07:46 PM
Don't be too sad about that 258. They are great motors with lots to offer.
If you are willing to invest the time and work, you can swap on a 4.0 head with FI intake and have one bad bump motor. You can also pull the motor and swap in a 4.0..... right after you use the 4.2 crank and rods and build the 4.0 into a stroker....... Just saying
Old 05-09-2010, 07:56 PM
Just not a fan of " 6 in a row " ( personal preference ). Always believed " V-8 makes it great ". Have been reading a lot about other people on the Eagle site doing that. They also add fuel injection. When they build theirs up, they go for a 4.7? 4.9? ( forget which ).
Old 05-09-2010, 08:38 PM
4.7 sounds about right. 4.6 is another good number to build them too. As strokers, they have a great amount of torque and HP (comparable to that of a SB V8).
Old 06-08-2010, 03:00 PM
Have a 360 ( AMC ) coming. Guy on the Eagle site is going to give me one. Think it's already partially disassembled. Says it needs rebuilt, but is a good core to rebuild. Maybe in a couple years, I'll get my 360 in there yet.
Old 06-09-2010, 02:32 AM
That car will scream with an AMC 360 in it. Do you know what year and what it is out of?
Old 06-09-2010, 05:24 PM
Didn't get a lot of info. just that it had been sitting for a while & had gotten wet, but should still be rebuildable. Price is right & beggars can't be choosers. From what he said, I think it's already partially disassembled.
Moparknighthawk
02-04-2014 05:21 PM
Josh
11-23-2009 04:43 PM
firecrew13
07-29-2009 01:41 AM
02-13-2009 06:21 PM
1982dodgeram
11-23-2008 02:42 AM
Quick Reply: Another AMC
