| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Ph.D in wheelinology
1974 J10
Well I figured since I have a 1974 AMC (Jeep) J10 pick up, I should post something about it in here. I've had it since 2003 and have been working on it since. I used it as my daily driver for a few months back in 2004 when I had to pull my tranny out of my dakota and rebuild it. After that I started to build it up for wheeling. It has an AMC 360 built, TH400 built, it had a qt case that I pulled and installed a dana 300 with clocking ring (hopefully soon i'll be able to install 32 spline outputs), dana 60 full floating rear axle out of a 79 J20, a HD dana 44 front axle out of the same j20 which will be getting pulled out so a chevy dana 60 SRW front axle to go in. The front suspension is stock leafs with 1.5" add-a-leafs and BJ's offroad lift shackles, the rear is 1.5" add-a-leafs and 1.5" blocks. I have cut the extended fender flares offs and have a set of 35x15x16.5 TSL super swampers mounted a do-it-yourself beadlock kit. The interior got gutted and 12 gauge steel went down for new floor boards, seats from an 03 jeep rubicon went it, I hand made the instrument cluster and replaced the shifter lever with a B&M sport shifter.
__________________
Tim and Heather 1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/ |
#2 (permalink) |
Here is a list of mods that I have completed.
Edelbrock 600 cfm carb Edelbrock performer intake manifold Edelbrock valve covers Trans-Dapt oil pan urathane motor mounts Energy Suspension urathane tranny mounts custom tranny mount adaptor custom tranny crossmember Clevite 77 cam, crank, connecting rod bearings chrome moly pistom rings new forged pistons - 9.8:1 compression 1", 4 hole carb spacer MSD standard pro-billet distributor MSD blaster 2 coil MSD 8.5mm spark plug wire set Flow Kooler waterpump K&N stubstack K&N air cleaner K&N exstream air lid Powermaster XS power torque starter Summit racing fuel cell, bed mounted Summit Racing K8600 cam w/lifters custom box around fuel cell in bed B&M Hole Shot 1200 stall converter B&M heavy duty shift kit B&M race ready rebuild kit B&M adjustable vacuum module B&M tranny cooler w/ 6" electric fan Autometer gauges/ new custom insturment cluster 16" electric fan for radiator Hedmen headers custom 2.5" exhaust ending right behind cab 2 Flowmaster 40 series mufflers manual choke cable tachometer tranny temp guage storage units mounted in bed for tools/parts BJ Offroad 1" heavy duty lift shackles, front Powermaster alternator header wrap Rancho 1.5" add-a-leafs front/rear Superlift 1.5" lift blocks rear Skyjacker shocks 03 Jeep Wrangler Rubicon seats w/custom brackets cut fender flares off Painless Wiring fuse panel heavy duty dana 44 front power trac locker full floating dana 60 rear locker rite locker steering box brace
__________________
#3 (permalink) |
This is what I have left to do to it before it is completely done.
4.56 gears, front/rear either 39" Iroks or TSLs front diff cover protection dana 60 front axle, detroit locker and SOA 14 bolt rear welded install chevy 64" springs under frame for rear suspension Optima 31a battery engine, transmission, t-case skid plates, 3/8 inch thick front/rear driveshaft 12,000 pound winch battery box CV shafts in front axle shave axles remove bed and add custom bed with roll cage
__________________
Tim and Heather 1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/ Last edited by 78D200 : 06-25-2008 at 02:24 AM. |
#4 (permalink) |
Here is a link to all the pics of the jeep. let me know if it works or not.
http://s149.photobucket.com/albums/s...J10/?start=all Here are just a few: ![]() ![]() ![]()
__________________
Tim and Heather 1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/ Last edited by 78D200 : 05-26-2008 at 04:59 AM. |
#5 (permalink) |
Well I picked up a set of 4.56 richmond gears for $210 yesterday and a Detroit Locker for $300 this morning, all for the front D60. Only reason why I'm not going with 5.13 gears like I wanted to is because the friend of mine that is giving me the 14B for free has a carrier and a set of 4.56 gears for it. No point in spending the extra money now just to change it.
Hopefully next weekend I'll be able to get the axles set up and maybe start to fit everything under the frame. I did notice that one of my front springs has a slight bend in it behind the axle. Once I get the rear susension all set, I'll place the front axle in and see how see sits before replacing the springs. At least that way there I'll be able to see if I need to lift the front end up higher or not. Also I'm picked up a 5'x4' piece of 1/4" alum diamond plate sunday night so the bed started to come off lastnight, which will make it easier to setup the rear. ![]() ![]() ![]() ![]() ![]()
__________________
#6 (permalink) |
Well Heather helped me out today with appling a coat of primer to the frame after I cleaned it up. I was cleaned up the alxes, primed and painted them. I'll be able to get a lot more done once the ubolts, spring plates, diff covers, 4" front leaf springs, and shock mounts come in.
Here are some pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#7 (permalink) |
Senior Member
nice progress! i bet it feels good to see it coming together :-)
#8 (permalink) |
Its still a long ways away but it does feel good to be getting somewhere with it.
__________________
#9 (permalink) |
Junior Member
Nice Build. Keep the pics coming.
__________________
Frank in Athens, GA rebuilding a 68 charger for my step-son in Iraq. |
#10 (permalink) |
If you click on the link in my sig, you can see all of them. I'vs got a lot going on right now with heather and I loooking at houses but I'm going to try and get a lot done before we actually move.
__________________
#11 (permalink) |
Well Heather had plans today so I had to paint the frame myself. I also got the bed bolted down and the fuel cell half way bolted down.
__________________
#12 (permalink) |
Rusty's 4" front leaf springs
![]() Hopefully sometime this weekend I will have the time to get them installed along with the front D60.
__________________
#13 (permalink) |
WOW Nice JOB there 78D200 looks like you have alot of time on her and boy its sure nice to see someone take time and build one of them up as nice as you are doing , sure would be neat to have a ride in it when your done
but you would have to drive over here LOL hope you keep up the good work and remember to take your time and it will all be fun in the end with a great time in the dirt / snow ewwwww snow i sure dont want to see that yet but its coming hehehe anyway great job and keep up the great work and we will be waiting to see her when it is all done ![]() |
#14 (permalink) |
Well Heather and I got the new front leafs in place. Heather has to work tomorrow so I'll probably end up burning out the bushing out of the chevy leafs and get them cleaned up. Hopefully this week I'll be able to get some bushings for them and get the rear suspension set up and ready to be welded in by next weekend. All that I'm waiting on now is the stuff I ordered from Ruff Stuff and I have to get a set or rebuild kit for the king pin joints on the front D60.
![]() ![]() ![]() I was also able to get my driver's side door latch problem fixed.... at least for the time being. :lol: ![]() ![]()
__________________
#15 (permalink) |
You know i have to say it but ( you might be a red neck if you have a gate lock on your truck door ) hehehehe
just kidden thats a good idea but what are you missing to make the latch work and good luck on the king pin joints <<<>>> keep up the good work ![]() |
#16 (permalink) |
its the latch itself. one of the springs and levers is broken and nobody around me has a pre 78 door latch. from 79 and later are different (figures since I have 2 79s sitting at a friends house). Once the cab doors start to take a beating, I'll be removing them and making new ones and will probably use a gate latch on both sides.
...... And yeah I am a redneck. lol ![]()
__________________
#17 (permalink) |
Well this morning I was able to burn out the old bushing out of the chevy springs and get things clamped into about the position that they will be for the rear suspension. I've got to get my hand on some bushing and metal sleves for the springs and then I can really start to set it up. It's starting to look like its coming back together once again.
__________________
#18 (permalink) |
Junior Member
wow lots of work here too, great looking project, i used to have a tonka toy of one of these, it started as brown, then painted burgundy. one of the toys that lasted as the others came and went. Glad to see the same happening here. As for the door latch, my dad used one of those little slide bolt locks used on house and appt doors years ago, on the inside of his 63 dodge panel delivery. He drove it for years like that.
__________________
a link to pics and info on my mopars www.fquick.com/dietz_diggler |
#19 (permalink) |
Thats a good idea. It would be less likely to get ripped off while I'm in the woods than the latch that I'm using. I'll keep that in mind though.
__________________
#20 (permalink) |
Tonight I got the new poly bushings installed and one hole drilling in the front two spring hangers for the rear springs. I had to drill the hole for the pop rivit for the crossmember that goes up and over right behind the cab. Once my stuff to bolt in the axles comes in next week, I'll be able to clamp the axles to the springs, set the vehicle on its own weight and start to weld in the rear hangers.
ITS STARTING TO COME BACK TOGEHTER!!! ![]()
__________________
#21 (permalink) |
This is all you guys are getting for tonight. I'll get some better pics up tomorrow night so you can laugh at my welding skills.
__________________
#22 (permalink) |
Well I got a little more done today. I was able to get all the hangers and shackle bolts torqued down and Heather helped out with getting some of the tires mounted on the beadlocks.
![]() ![]() ![]() ...... and yes this is a 3/8" thick diff cover. ![]() ![]()
__________________
#23 (permalink) |
Well Heather and I got the wheel studs pounded into the hubs for the 14B and got the backing plates and the brakes on. Just have to get the right drums for it and then the tires will go on.
Heather has been a huge help. ![]()
__________________
