My Jeeps
Figured I would make a post with some photos of my current Jeeps.
Here is the wifes DD. 2007 Liberty. It has a Frankenlift and 235/85/16 Mud Terrians. (the lift is recent so not many pics of it yet) http://i239.photobucket.com/albums/f...liberty001.jpg http://i239.photobucket.com/albums/f...tedrock013.jpg Here is the last trip out before the lift. After seeing the undercarriage I kne wit was time My 94 Cherokee that is still in the garage getting built. It is getting a newer 29spline 8.25 rear with welded carrier, lock right in the front d30, that has the newer 297 joint shafts, 4.5" lift, and 33" mud terrians. When it comes out of the garage it will also be fully caged with rock sliders, bumpers and on board air. http://i239.photobucket.com/albums/f...herokee004.jpg Its CURRENT condition http://i239.photobucket.com/albums/f...herokee009.jpg My 90 DD cherokee, that actualy belongs to the mother n law but I claim it as mine since I drive it and keep the thing running. I also take it int he woods where it shouldnt be http://c1.ac-images.myspacecdn.com/i...76ee857d48.jpg |
that looks like so much fun:D
i love jeeps and love wheeling so much more.
That 2 door can be made into such a trail rig. With the two door cherokees, You can cut the rear fender wells to fit larger tires. Axles from a N/T FSJ can fit into the suspension which means hello dana 44s and up to 37s fit built right!:D |
Nice work.:D
If I upgrade my cherokee axles from anything that didnt come stock in one I'll go 14botl rear and 60 front.
then you would have to get a stroker kit or a stroked motor just to turn the tires that the axles could handle and even then it would be a bit much for a 4.7 stroker. Not to mention, if you went with a V8 you would have to reinforce the subframe so much it wouldn't be worth it.
I just thought that a set of D44s built right and 36s or 37s would look sick on a 2 door cherokee. Although I don't you could then drive by cops without them looking at you with the "I should pull him over" look. hahaha. They look good though. that 8.25 will be much better than the D35 c-clip axle. Is the front 30 a HP? |
Yes its a high pinion with 297 ujoints.
Shadow Wheelin'
I can not even 4 wheel over a deep shadow with out bottoming out my front air dam. Some days I really miss my real Jeeps.
The 07 SRT8 is fast but rather one dimensional. . . Regards |
like it brother!
I Like
