2013 Chrysler 200 Headlight issue
OK look, imma be straight up...
i tried hooking regular HIDs to my 200 and lets just say, i didn't get the glowing blue glory i expected. i didn't get nothing at all for that matter. i tried with my fog lights, and then i tried with my regular low beam headlamps and so far, only one light came on.... and that is the only light i have left. i didn't find out til later that i was suppose to use a harness for both sets of lights because of how they're designed. Being as though my 200 has DRLs, there isn't a fuse in the fuse box for neither set of lamps. and now I'm all out of ideas; things are starting to go way father than my understanding, and my only option is using the Harness i ordered to power both headlights. The only way i can make that happen is by using the one side that does work, but if anything goes wrong then I'm outta all FOUR lights.... PLEASE CAN SOMEONE HELP ME, and help me find a cheaper way. what is powering these headlights???? where can i locate and replace the switch ??????
Not sure what you could have done wrong if you installed the whole kit.
Are you sure you have a good ground? And are you sure you didnt hook up the Lamp Wires backwards?
If all is well with all that. I would call the MFG... Somethings up....
Xenon Supply had a good known kit for the Chrysler's a few years back.
Keep us posted on what you find...
andreimon
10-06-2016 12:24 AM
