Clutch replacement/repair cost
Old 11-26-2013, 02:44 PM
Abuong01's Avatar
I've been quoted 550 for parts and 805 for labor to replace the clutch in my 64 v8 barracuda. Apparently the original 9" isn't available but that shouldn't be an issue given they availability of 9.25 and 10"
Any thoughts....my first barracuda and I'm needing some help to know what makes sense for a replacement. I found OEM plus throw out bearing for about 225 online. Why 550 bucks?
Thanks in advance for the help guys
Old 11-26-2013, 04:15 PM
If you go to a 10" clutch you would need a flywheel, clutch disk, pressure plate through out bearing and maybe a new belhousing ??? I would check with Summit Racing OR Ebay $800 for labor ??/ or is that the total ?
Old 11-26-2013, 04:29 PM
http://www.autopartswarehouse.com/sk...E52541403.html
The listing says 10" clutch ??? Have you taken it apart ? Was it changed from a 6 cyl ?
Old 11-26-2013, 04:30 PM
moe7404's Avatar
on some older mopars I.E. 9" a 10"-11" clutch may not clear the bellhousing. if memory serves me. right.
Old 11-27-2013, 10:21 AM
Abuong01's Avatar
They quoted 550 for parts and 800 for labor on the original quote. Now asking me to call them because they cannot get the 9 inch which was supposed to be original equipment in the 273 V8.
Old 11-27-2013, 11:59 AM
800 is terrible !!! You can change a clutch in 4 hours
Old 11-27-2013, 12:42 PM
Abuong01's Avatar
They have 8 hours at 95 per hour. Pull the transmission, etc is what they said had to be done. Feel like I'm getting boned
Old 11-27-2013, 02:32 PM
Here's something 9 1/4 clutch listed for a 6 cyl but may be what you need ???
http://www.autopartswarehouse.com/sk...%26+Drivetrain
and someone who does clutches and has the air tools could probably do it in 2.5 hours + 1/2 to jack it up and support on jack stands.. 4 bolts and the drive shaft comes out, 2-3 bolts and the shifter comes out 4 bolts on the cross member 2 bolt on the trans mount. 4 bolts and the trans comes out !! 2 bolts for starter 5 bolts for the bell housing. 6 for the pressure plat and another 6 for the flywheel... an an air ratchet /impact makes quick work of it... Send the flywheel to machine shop and have it re surfaced re assemble with locktite on bolts
Old 11-27-2013, 06:22 PM
mikerp76's Avatar
if it takes them 8 hours they must work really slow.
Old 11-27-2013, 08:12 PM
The biggest scam is the labor rate manual
Old 11-27-2013, 08:52 PM
Abuong01's Avatar
Thank you everyone for the help and education. I'm going to challenge the labor hours..is there a "book" that suggests how long something should take like there is for modern cars.
Old 11-28-2013, 01:26 AM
No sense challenging them... LOOK for a different mechanic !!!!
scotty
12-20-2011 12:58 PM
sebring28
11-05-2011 03:50 AM
dnlwstwd
10-12-2011 08:08 AM
RROriginals
08-23-2010 02:44 AM
JeepChryslerDodge
02-12-2010 03:58 PM
Quick Reply: Clutch replacement/repair cost
