Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > A-Body > Cuda Specific Discussion
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-13-2007, 04:02 PM   #1 (permalink)
wtim47
Junior Member
damn wiring need help
ok so i was driving my cuda around and it just lost all electrical. I got it home found that power wire coming from the battery to the terminal block blew the fusable link. Replaced that now I have power everywhere but it still wont even crank via keying it. I can jump the solinoid but still no spark. Its got 10 volts to the coil. Any help would be great.
wtim47 is offline   Reply With Quote
Old 06-08-2007, 05:51 PM   #2 (permalink)
cudajim
Junior Member
You didn't specify what year your car is but you can get schematics for free at:
http://www.mymopar.com/wiringdiagrams.htm
Where to start with your limited information... you may have a problem in the dash area. Check your ammeter connections and/or bulkhead connections for opens. Also check your neutral safety switch for correct operation if your starter is not working. I can get more specific if you define the problem better.
cudajim is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
