Go Back   Mopar Forums > CLASSIC DODGE, CHRYSLER, & PLYMOUTH MODELS > A-Body > Cuda Specific Discussion
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 03-20-2007, 09:14 PM   #1 (permalink)
Sanitarium
Junior Member
Send a message via AIM to Sanitarium Send a message via MSN to Sanitarium Send a message via Yahoo to Sanitarium
Thumbs up R U Serious
You have a place just for cuda's?
__________________
I write death threats to white jazz critics signed 'The Mau Maus of East Harlem'
Sanitarium is offline   Reply With Quote
Old 03-22-2007, 11:20 AM   #2 (permalink)
1 Bad Mirada
Administrator
1 Bad Mirada's Avatar
as time goes on, we will have an area just for every model!
1 Bad Mirada is offline   Reply With Quote
Old 03-23-2007, 01:02 PM   #3 (permalink)
Sanitarium
Junior Member
Question
That's awesome. Doesn't look like it gets used much though. I try something.
__________________
Old 05-26-2008, 10:14 AM   #4 (permalink)
qwave12
Proud new Barracuda owner
nobody posts
hey i'm new to this forum, but I have been a member of bimmerforums and rx7forums for years and they have thousands of posts and I can usually find info by searching and not posting, but this must be a new site because there is very little infor here.
I have a 67 Barracuda. I got it tuesday. I had new tires put on it on the front(backs were new) My freind owns the tire shop he snapped all 5 of the lugs off the passenger side(left hand threads). Then to make matters worse couldn't knock the old lugs out, so machine shop "presses" them out. I think they drilled it, because the holes were smooth as hell. so new lugs don't fit they don't tell me and tack weld them in. new tire new lugs on car tightened down drive home 15 miles no problem go to cruise in next day get 4 miles from home hear a loud noise and bam 3 lugs snap off. Now I have a wallowed out drum, hub, broken back plate, and broken brake wheel cylinder. I am having trouble finding the parts, Year one dosen't have them and I can't find anybody on here who has done a disc brake conversion for the barracuda. If anybody can help that would be great
qwave12 is offline   Reply With Quote
Old 07-20-2008, 07:05 PM   #5 (permalink)
K Wolf
Junior Member
Hello, one of the disk brake conversions you may want to research is the '73 and up swap. The upper A-arms, ball joints, spindles, calipers, and rotors (and maybe the master cylinder) from a '73-'78 A-body are swapped into an earlier A-body. One area of concern (a benefit IMHO) is that the '73 and up A-bodies use a 5 x 4 1/2" bolt pattern wheels instead of the 5 x 4" bolt pattern your car originally came with. That means a much wider selection of wheels available for your car if you change the bolt pattern on the rear end as well. For me, it means aftermarket axles in an 8 3/4" A-body rear end. If you don't need the toughness of the 8 3/4" rear end, you could go with a complete rear end assembly from a '73-'78 A-body (I don't know much about the different rear ends available in the '73-'78 A-bodies, other than that they are all large bolt pattern.)
I've not done the conversion yet. I'm in the process of buying the needed parts for my '68.
Karl
K Wolf is offline   Reply With Quote
Old 08-16-2008, 04:44 PM   #6 (permalink)
challenger
challenger's Avatar
For qwave12 <<<>>> if you haven't yet found brake kits here are a few to check >>>> www.mpbrakes.com and www.ecihotrodbrakes.com ... i would make who ever did your axle studes buy you a set if it were me
challenger is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
