hydraulic roller cam on small mopar LA ( help )
i have 1978 360 mopar LA engine and i wont installation hydraulic roller cam ,
what can i do to install it and what do i need part for install preferred from summit racing thanx to warm attention :nx: |
Hughes makes the lifters with link bars that drop in and clear the lifter bores with out grinding. They make ones for oil system as is on the LA or "oil thru PR" if you want the stud mounted rocker heads... You do not have to worry about Cam walk like Chevys.
You can NOT use magnum roller stuff in the LA. |
