Low 9 sec Cuda .. 28x10x15 or 29.5x10x15 ?
Old 03-22-2015, 01:30 PM
raffaplymouth's Avatar
In my Cuda ..would jump from 28 to 29,5 for improve 60 ft and top end speed ... Now with 28 tires with 4.10 ratio my best ET is 9.79 at 142 mph ..1.48 60 ft .. 7200 rpm at finish line .. Look like too rpm ?? Because my power peak is at around 7000 rpm ... My goal is low 9s !!
Old 03-22-2015, 01:32 PM
Sorry .. Would jump to 29,5x9x15 Not 10
Old 03-22-2015, 03:59 PM
moe7404's Avatar
my pappy allways said. the faster you go the harder it is to go faster.
Old 03-22-2015, 04:28 PM
motasupra's Avatar
That car sounds awesome. We run a 29.5x10.5W R15 its a total of 13" wide and goes like hell off the line. but the best pass in our car was 10.30'S
Old 03-22-2015, 09:05 PM
The added weight May make it go slower ????
Old 03-22-2015, 09:30 PM
Drag Pak's Avatar
Raffa
pm sent
Old 03-23-2015, 03:36 AM
wow !! you have this 29.5x10.5 with 10" wheels ??? wich backspacing ??? i think not fitting in my cuda with factory leaf spring location and factory fender !! remember my car is streettable .. i drive everyday .. and in september my best ET was 9.78 and 1.48 60 ft
Old 03-23-2015, 04:00 AM
hosting immagini
Old 03-24-2015, 07:55 PM
motasupra's Avatar
Our back fenders are rolled. we may go back to stock fenders when we put it back on the street. 10" with 5.5 back space weld drag lite. calvert mono leaf rear and caltracs.
P.S. that car is bad. pump gas?
Old 07-15-2015, 01:40 PM
.. Yes Pump gas .. In Italy Pump gas is available in 100 octane ... In The last race this car had Made 9.64@143 60 FT is very bad 1,51 ..this car have stock 45 years Old leaf Springs ... And Caltracs ..
28-10-15 tires ...im working for install mono leaf and 9 way shock and offset hangar for move The leaf inside !!
Old 08-10-2015, 07:53 PM
Guys . Anyone know the difference in the springer hanger ?? Have two hole for the spring eye ... Wich is better ? ... Lower or upper ?
Old 09-10-2015, 08:50 AM
caricare immagini
Old 09-10-2015, 08:59 AM
Drag Pak's Avatar
Bent housing? Got hook? Typical 8 3/4! Dana 60 time?
Old 09-10-2015, 09:10 AM
Magoo's Avatar
Thumbs up Your Cuda
Originally Posted by raffaplymouth
--- Neat - Old Mopar.
Old 09-10-2015, 09:23 AM
YES !!! DESTROYED AFTER 5 PASS WITH NEW MONOLEAF !!!!! IM UNDECIDED IF PUT NEW CASE WITH BILLET CAPS .. BUT I DONT SUCCESS TO FIND 4.10 RING AND PINION PRO GEAR !! YOU THINK IS TIME OF DANA 60??
Old 09-10-2015, 09:25 AM
image share
Old 09-10-2015, 09:28 AM
THIS IS THE LAST PASS 9.7@146 KMH
free image hosting
Old 09-10-2015, 10:05 AM
Drag Pak's Avatar
Time for Dana S60 (Strange) with chromoly tubes, spool and gundrilled axles.
I was waiting for these pictures to show up!
Old 09-11-2015, 05:32 AM
If you stick with the 8 3/4, you need a spool and you should be changing the ring a pinon every 100 pass's or so (before it breaks).
I'd say it's time for the Dana, and you probably broke your trans also.
Old 09-11-2015, 01:58 PM
i have found in italy a Dana 60 OEM 1967 at good price , i can convert in 35 spline ... have power lock carrier
Old 11-27-2015, 06:54 AM
New Rear End !
invia immagini
Old 11-27-2015, 07:06 AM
host image
Old 11-27-2015, 08:18 AM
Hope it Works as Good as it Looks Raffa.....
Did you stay with the 4.10's or go with a 4.30 gear?
Hoping for the new best of a 9.50 for you....
Old 11-27-2015, 10:18 AM
  #24
Drag Pak's Avatar
You might want to try that Caltrac bar in the lower hole/closer to parallel to the ground.
Old 01-05-2016, 02:25 PM
  #25
Hi... thanks for this info ....!! you think is better on lower hole ??? i can also move the spring eye location from lower to upper hanger hole ... let me know ...
Old 01-05-2016, 04:08 PM
  #26
Drag Pak's Avatar
I think you have to test to find out what gives the best 60 ft. I believe there will be a difference from top to bottom, depending on how much axle - body separation you get/need and still dead hook.
raffaplymouth
09-20-2016 03:06 AM
AARinOntario
08-09-2012 08:45 AM
70newport
03-26-2010 02:34 PM
summerj
02-06-2008 08:34 PM
BRAKE
10-24-2006 09:18 PM
Quick Reply: Low 9 sec Cuda .. 28x10x15 or 29.5x10x15 ?
