Go Back   Mopar Forums > RACING / RECREATIONAL > Street n Strip
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 03-01-2008, 12:53 PM   #1 (permalink)
azzkikr
Junior Member
pushrod installed wrong
Just wondering if anyone had this issue before, just had a stroker motor built 400-512, drove the car a few miles and rocker arm was loose and push rod danging around. Builder came out and put a new rocker arm on and replaced pushrod, same thing happened a few miles later. Has roller lifters, solid cam, anyway i pulled valve cover and was able to position the pushrod in the hole of the lifter, they had it installed sort of on the side, and i was wondering why there was much more thread exposed on the adjustment screw. So now after driving for a short time, engine is missing badly, did a compression test and now 0 compession in that cylinder. Haven't pulled the head yet. (indy), I don't think the car was ever running on full 8cylinders but still pull like a monster so didin't think anything was wrong, What do you think is damaged, valve, stem, guide? Hopefully nothing major. Builder says i must've overreved it, but when i tell him this story, he does'nt get it. Opinions?
azzkikr is offline   Reply With Quote
Old 03-03-2008, 09:45 PM   #2 (permalink)
CAT-TECH
Member
CAT-TECH's Avatar
We get these issues on many diesels that come into the shop. We either find a flattened cam lobe (maybe not properly broke in?) or a lifter roller that walked out of its seat. Your adjustment screw should not be any different thread height. Are you sure he put the same length push rods in? Check to see if the push rod is bent too, we see that alot. With what you say "they had it installed sort of on the side" It might be a bent push rod.
CAT-TECH is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ok can someone tell me where I went wrong? rampage_82 General Technical Questions 3 12-07-2007 09:22 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
