1970 Cuda 496 10,3 sec
#63
Raffa.... You need to check the Total Octane... Not just the advertised Octane rating.... But if you use it and not have any detonation you will be fine. Keep a good eye on the plug reading...
Oh... And did you see you WON the "Mopar Of The Mouth" on the site here !!!!!!!!!!!
Love the Web Site also Raffa...Looks great....http://www.2000motors.it/
#65
hi guys .. i have the race in 14 september .. this is my news:
new tires 28-10.50 MT
110 octane fuel
new fuel jet plate
new cal tracs adjust from lower to upper hole
new valvebody billet from john cope racing
lowering the front of 1" for better straight at high speed ? can worse my 60 ft .. now is 1.51
any advice is good for me Thanks !
110 octane fuel
new fuel jet plate
#66
110 octane fuel
new fuel jet plate
110 octane fuel
new fuel jet plate
#70
Raffa
That thing is coming along nicely.
There are some high 8 sec cars with that mph.
I think there are possibly some gains yet to be made.
What is your : Launch rpm
Torque Converter flash rpm
Maximum engine torque rpm
Maximum engine horsepower rpm
Trap rpm
That 60 ft might have room for improvement?
Trap rpm
#71
Raffa
What is your : Launch rpm 1600
Torque Converter flash rpm 5000
Maximum engine torque rpm i dont know ! No dyno test in Italy
Maximum engine horsepower rpm 7300
Trap rpm trap??finish line rpm ? 7200
Rear end ratio 4.10
Tires MT 28-10,50-15
Tire pressure 10.5 psi
Best 60 ft 1,49
Rear end ratio 4.10
Best 60 ft 1,49
#74
#77
That should knock about 300 RPM off it........
I dont see 7300 Being a problem as long as the motor is still working up there.
But if your just looking to knock a few RPMs off the top... Then try the tire change.
But Some times, if this has not been a problem before? "Climbing in RPM" this could be the result of the Converter slippage....
Question:.... Still has the 4.10 Rear Gear? and still running down in the 9.80 range?
#78
#83
hi Guys ... this is the last news !
Best ET 9.64@232 with 400 hp spray !!
best 60 FT 1.49 sec
finish line rpm 7400 ( Too high !!!) with 28-10- tires
i would improve my 60 ft !
im working for install 30-12 tires but need leaf spring offset hanger and shackle ...
anyone have installed on E Body 12" wide tires ? i think to install 10" wheel with 6.5 backspace ..with 29-12-15 good year drag slick
im also undecided if put stock height leaf springs or lowered ...
thank you guys !! im happy for any advice
best 60 FT 1.49 sec
#86
Raffa
Have you considered going with a radial slick.
The ones noted work well on a 10" rim into the low 8's in Stock Eliminator and they should fit your car easily.
Hoosier
18212 9.0/30.0R-15 Radial*** C 9.0" 29.9" 94.0" 8-10" 8" 11.0" C06
Hoosier
#87
radial ??? I thought it was worse in 60 ft !! my car weight is 3500 lb
#89
#90
Raffa
Going through some slips and I note a BS/A leaf spring Camaro at 1.337 - 60ft.
I would have to research it, but I believe there is a 1964 CC/SA 3800 lb Plymouth here in Div 6 that would be very close to me (60 ft and et.) as he has run with me.
