1951 Chrysler crown imperial
Old 02-26-2017, 03:33 PM
Robert Schwarz's Avatar
I have a 1951 Chrysler crown imperial with the 331 hemi. I recently acquired a 440 big block matched with a 727 torque flight transmission. How hard is it to replace the 331 with the 440?
Old 02-26-2017, 04:46 PM
Quit a few mod's to get that one set up, From what I understand.
Welcome to the site from SO-CAL....
Old 02-26-2017, 06:57 PM
It's possible that there is a combination of parts to bolt your 440 in, but most likely you will need to fabricate all motor and transmission mounts, drive shaft, shift linkage etc.. You will need to come up with a larger radiator also.
Old 02-27-2017, 06:36 PM
Low Rider's Avatar
440
I am in the process of this same swap in my 53 Wagon. It isn't a difficult swap but you will need all the parts Iowan suggested plus you will have to swap your power steering with a late model 53 or 54 unit. Motor mounts will have to be fabricated but cross members can be purchased at Summit.
You should consider an 8 3/4 rear end. The 440 is a little much for you stock rear end.
Good luck with you project and let me know if you have any other questions.
Tom (Low Rider)
Souprmom
07-11-2013 09:18 PM
76 Doba
04-09-2013 11:00 AM
76 Doba
06-25-2012 06:56 PM
Barracuda64
08-20-2011 06:34 AM
grissomracing
11-18-2009 05:34 PM
Quick Reply: 1951 Chrysler crown imperial
