1974 swinger engine swap
Old 07-24-2014, 05:50 PM
randy8's Avatar
i have a 74 swinger that has a slant six and i want to put a 318 in it i was wandering how much work is involve in the swap
Old 07-24-2014, 07:02 PM
What year is the 318, what is it out of?
Is this a pre-68 318, aka "poly?" Then no
If this is a magnum, some differences from below
If this is a LA series 318, then:
"The factory way."
You'll need a V8 K member (front cross member)
"the non factory way." Go here and order what is called "swap" engine mounts, which are special after-market mounts that hook to the /6 K member and allow you to bolt in the V8
http://www.engine-swaps.com/
If you have a stick, you'll need a different bell, flywheel, and clutch, and probably some clutch linkage pieces
If you have an automatic, you'll need a long shaft either 904 or 727 to fit the V8, along with related hardware. This gets tricky, as "Ma" balanced the external balanced engines like the 260 by using weights welded to the converter. You can knock those off, for an LA 318, which are internally or so called "neutral" balance
You'll need a "car" engine pan as opposed to a pickup or van pan, exhaust manifolds to fit the body / engine combo. Generally, van / pickup manifolds won't work.
Obviously, you need exhaust system
Radiator "might" work. The top connection is on wrong side, but you can use a flex hose.
If you have power steering, you'll need a pump and brackets to fit the 318, and compatible pulleys. Nothing off the slant will work, maybe except for the actual pump itself
Minor changes in the wiring harness, pretty easy. The alternators are the same so long as they are 1970 or later
Old 07-24-2014, 07:37 PM
Lots of people have do it But you need to change the complete drive train. Best done if you have a donor car
Old 07-24-2014, 10:57 PM
Very good point and I forgot to mention........you probably have the tiny 7 1/4" rear axle. This will break fairly quickly with any horsepower at all.
Old 07-29-2014, 03:40 PM
SspazZ's Avatar
440, could he just not find some .087 torsion bars and the motor mounts(no k-frame replacement) from Schumacher.
http://www.engine-swaps.com/Pages/Products.html
Old 07-30-2014, 09:24 AM
I posted the Schumacher link
Frankly, I'd go with much larger than V8 factory T bars. MUCH larger. These cars were "under" sprung badly. The fact is, it is not the DESIGN of the suspension that is so bad, it's the springs, lack of brakes, anti sway bar, and shocks, along with junk factory tires, that made these cars such mundane drivers.
A 74 should already have disc brakes. The addition of decent T bars, re-work the rear leafs, even a factory front anti-roll bar, and along with new parts and alignment, and good shocks and tires, and these cars WILL handle.
Profyrfyter
12-17-2020 01:22 PM
Ronvonie
12-07-2014 04:36 PM
72bird
08-04-2012 09:58 PM
mopardrt
02-09-2010 06:20 AM
Jesan138
05-18-2009 08:15 PM
Quick Reply: 1974 swinger engine swap
