67 CHARGER NO TAIL LAMPS OR DASH LIGHTS
Hey all,I have a 67 charger,last week the dash and tail lamps all went out at the same time. This car is all original,never restored,no rust anywhere at all,so i have ruled out corroded wires. Any ideas for me?? There is no fuze in the block for tail lamps only. Amy suggestions on what to check next??
Thanks all Marty |
There HAS to be a fuse for that.
Back in the day they had the dash lights in with the tail lights so if your dash lights were out you usually knew that your tail lights were out , that was just a way to know but i would just replace all the fuses anyway if they are old it never hurts and they are cheap versus a ticket but if there is a fuse for the dash lights chances are it is bad but also there might be a inline fuse , still if nothing i would just do the old trick and plant a wire on the neg; side of batt; and run it to your tail light bulb and put it in between the side of the bulb and the casing and you will have a good ground ( just one way to rule out grounding ) hope it will help you but my guess is its a fuse:)
