a518 issues
Old 11-24-2014, 10:32 AM
stoffy's Avatar
a518 issues
hi swapping a518 into 84 dodge d 250 with la360 what do i need as far as flex plate and t/q. I have the original 318 flex plate and t/q from donor 92 dakota there is a weight on the t/q should i knock off ?
Old 02-25-2015, 03:40 AM
The 318 is internally balanced while the 360 is externally balanced. As long as the flex place and TQ are balanced, you should be ok.
Old 02-26-2015, 02:16 AM
Gorts 5th's Avatar
Smile
Welcome
do not knock off the weight ...you nd a tork converter for a 360. It.will have a.larger weight to balance the 360.
other than that its a straight swap
did you happen to take the lock up and overdrive wire pigtail
how will u activate them
Old 02-27-2015, 05:13 PM
Get a B&M flex plate for a 360 Carefully remove the weight from the converter
Old 02-28-2015, 03:38 AM
Gorts 5th's Avatar
Smile
For what
just get the corrrct. Tq
a 2000 stall mopar tq with lock up is the safe way to go when you start knoking weights off.yor askin for trouble
85dodgeram350
01-04-2015 02:04 PM
orangesteve
27
04-08-2013 02:59 AM
maca
18
01-14-2013 04:24 AM
85dodgeram350
10-31-2012 05:38 PM
erwatt
02-12-2009 03:45 PM
Quick Reply: a518 issues
