beer barrel woes.
beer barrel woes.
I have a 2000 dakota with a 5.9. Does anyone make an intake manifold for fuel injection to replace the beer barrel? The under gasket is leaking AGAIN. I drive it daily so the mopar 1500 - 6500 single plane intake is out of the question. Any help is appreciated.
Those are the only intakes that I know of for the Magnum motors. I think someone else posted up something about another intake a while back but can't remember who or what brand.
on
Hughes F1 Airgap.
There is also a replacement Plenum plate that will cure the gasket blowouts.
http://www.hughesengines.com/Index/p...p?partid=24773
http://www.hughesengines.com/Index/p...p?partid=26190
on
Here is an intake that I almost purchased until I found out it was for the magnum heads only. This auction has ended already but might be worth looking at to get idea's
ebay item# 220734423848
Good luck.
Joe.
Good luck.
Joe.
on
Welcome to the forum.... Hope you get that manifold problem corrected.. Be sure to check out the Mopar of the Month contest.. Each monthe we select a winner by membership vote... You have a vote also. So why not use it......
Polara-Lee
06-18-2020 09:41 AM
