Go Back   Mopar Forums > GENERAL > New Member Section
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 09-24-2008, 05:27 PM   #1 (permalink)
1toDV8
Junior Member
need help with INFO please!
Hey all. i signed up to find some info. maybe you can point me in a good direction. If so thanks in advance!
My boss wants me to do a project swap for him on a 1970plymouth fury III, he has asked me to install a 2000 360 auto from a dodge maxi van into it!
Now I'm not worried so much about the swap, its not that hard to do as far as my skills. What I'm looking for mostly is where to find info on the car and the new swap engine and trans.
I'm a professional diesel mechanic for a living so I have no fear of this kind of work. I'm also a member for several years now of LS1tech.com and v8rx7forum.com. By this point you probably figured out I'm a GM guy! Sorry.
I'm proud owner of a 1986 RX7 with a 2000 LS1/4L60E from a vette installed. Its very fast and handles as good as any car on the road IMHO.
My car runs in the lower 12's on drag radials and has a top speed of about 165MPH. while still getting 25MPG (if I keep my foot out of it!)
I need stuff like PCM pinouts for the engine trans and wiring diagrams for the car. I really would like something very clear so when I design the new curciuts for the newer engine I can have a realistic chance of getting it right the first time and not (as we say in the diesel world) not let the smoke out of the wires?
The rest of it will go fairly easy IMHO, but the wiring has to be right!
1toDV8 is offline   Reply With Quote
Old 09-26-2008, 06:30 PM   #2 (permalink)
Ph.D in wheelinology
Send a message via AIM to 78D200
welcome to the board!
I'd say your best bet would be to find a 2wd truck or a fullsize van with a 5.9 in it. they will have a 2wd tranny already and you can grab the harness and computers. thats what I would do, minus I would look for a dodge ram 1500 SST or a dakota or darango R/T motor and just get a 518 or 518A tranny from a salvage yard and build it up that way he would have OD.
__________________
Tim and Heather
1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds
jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/
78D200 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
new need 65 barracuda info dodgeb New Member Section 4 09-05-2008 01:46 PM
Need HEMI info!!! tjoker336 New Member Section 2 04-13-2008 07:01 PM
1971 charger info big block info 71charger B-Body 1 04-02-2008 06:22 AM
In Need of INFO 72cuda543 General Discussion 2 01-10-2008 11:08 AM
8 3/4 info 79mopower General Technical Questions 0 12-14-2006 05:05 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
