Should I get it?
HI,
So very new to both forums and hot rods. but here i go. I just got a 1964 Chrysler 300 4 door hard top with a 383 auto. Needs work. I have a chance at a 77' 440 industrial with an auto trans both in a crate nu-used for $2600. I think I will get better heads for this. I guess i need to do a gasket job on both and lube the bearings, but do "you" think its a deal. I understand tha I will need a machine shops help with the 383 and all the parts to fix it up. It has 30,000 on this motor. I think (maybe rolled over to 130,000) hard to tell.. I'll take any and all advice. Thanks in advance for help. Sion. |
Depends on the budget..... Some parts you are not going to be able to swap and you will need to acquire.... Just my 2 cent
Welcome to the site |
(Post 134202)
Trans probably will not fit ? 64 is Cable shift ? Engine unknown ??
