Torque Specs '72 Valiant
Hello I am planning on replacing my outer and inner tie rod endings as well as my upper and lower ball joints. I have a 1972 Plymouth Valiant. Does anyone by any chance know the torque specs? and if anyone has advice of any kind that would be help full.
Just tighten them tight and then if you need too, Back them off slightly to align the cotter pin hole to retain the nut...
50 ft lbs should be more than enough... keep tightening until the cotter pin can be inserted
