1999 Dodge Ram 1500 4x4
Old 07-30-2016, 02:45 PM
Jimjimbo1942's Avatar
Check engine, brake, abs on dash. How many sensors and locations. What are steps to fix problem.Oh forgot speedometer works till I use brakes. Help !
Old 08-01-2016, 06:14 PM
You need to put it on a scanner.. The speedo is controlled by a sensor on top of the rear diff. IT can also cause an ABS light
Old 08-02-2016, 02:58 PM
Jim.... Check and make sure the fuses are good under the hood.... The ones in the black distribution box... Make sure the fuses under the Black clip and the Yellow or White are good.... Those are the main fuses, sounds to me like one of those blew out?
chuckorr
02-07-2014 04:20 AM
checho
10-04-2011 02:28 AM
Polishdog
02-01-2010 01:04 AM
plymouthrr1985
05-25-2009 05:22 PM
Ekimwood
03-15-2009 04:40 AM
Quick Reply: 1999 Dodge Ram 1500 4x4
