Cuda won’t turn over after a short run
Old 03-25-2022, 07:50 AM
Teddaniel's Avatar
1970. 383 cuda starts right up and drives fine. When I go to start it after driving say a 1/2 hour or so it won’t turn over. It has a new battery. When they jump it it takes a while for the jumping charge to take effect to even turn the engine over. If it cools down for 2 hours it starts right up. Any thought on what might be wrong?
Old 03-25-2022, 08:59 AM
Archer's Avatar
Ted -
The engine (starter) won't spin or the engine won't ignite?
Heat expansion resulting in a ground short?
Bad electronic control box? (Been there, done that.)
Old 03-25-2022, 09:00 AM
Does it have headers on it because it sounds like you need a starter or a heat shield for the starter...
Teddaniel (03-25-2022)
Old 03-25-2022, 12:11 PM
Teddaniel's Avatar
Is there a test I can do to prove this out
Old 03-25-2022, 01:40 PM
I would first verify the connection of the battery cables (both of them) are good and that the cables are in good condition. I suppose the starter solenoid could be giving up also. To check out the starter you need to pull it and have someone run a load test, ORille’s, western auto, Advance Auto etc.can do it. The soleniod can be replaced cheap enough same with the cables.
Old 03-25-2022, 01:43 PM
It’s possible that your new battery is junk also, I had that with a tractor once.
Dutch
07-02-2020 09:21 AM
gregsgs@yahoo.com
05-13-2012 08:19 AM
Fitchley Hornbuckle
04-26-2009 02:26 PM
Quick Reply: Cuda won’t turn over after a short run
